My question is how to stream video with subtitles on my Sony Bravia KDL-40EX520 from my Xperia sola. I im using wi-fi direct and the video play very smoothly, but when the video's sound is not on my language its not that comfortable to watch it. I have read so many posts but i dont find that what im searching for. I read that both of the devices does not support screen mirroring. Any help would be great.
To be honest I have no idea. My knowledge on mobile connectivity is limited at best.
A couple of ways to get your questions answered:
Hi there
The EX520 does not support subtitles (or .srt files) via DLNA streaming.
So what about micro USB-HDMI cable? Does it working with both of my devices?
JFYI - Homestream supports subtitles over DLNA, so you can get them to work that way.
http://community.sony.co.uk/t5/Blog-News-from-Sony/Homestream-Media-Sharing-from-Sony/ba-p/1262890
Thanks
Just to add, Homestream is not supported on Xperia, so you would need a PC/Laptop to stream instead.
Ah sorry, I missed that first part. Indeed the challenge is that natively the TV's don't support streaming subs, so you need to include the subtitles as part of the DLNA data stream from the DLNA server. I know that Homestream can do this ( as I commissioned it
) and there may be other 3rd party pieces of software that can also do it, but it will be a software feature rather than something that is natively supported by the device if that makes sense..
