We purchased an out of the box Sony XBR49X900F and the remote did not come with the tv. We are trying to turn off the screen saver which interrupts all shows after 5 minutes. We do not have the original tv remote and are using a remote from FIOS for our cable system.
Any help is appreciated!!
Nevermind ya'all, I found a universal remote and programmed it and followed earlier steps in another thread to disable the screen saver and the 'retail options'. All is good!
