My KDL32EX503U currently uses 5w in standby mode which is way off the 0.2w advertised. I have checked auto start and it is off. Are there any other settings that need adjusting to get nearer 0.2w ?
Hello Bodrake,
This is one of 2 things, you are either measuring when the TV is in active stand by or the most likely issue is measurement method.
Some instruments measure V*I and automatically uses this measurement as the power consumption. The problem is in standby the Voltage and current are out of phase and therefore a power factor has to be applied.
There are meters available that do take the power factor into account.
Hope it helps.
Hi Pcadjb,
i have taken more measurements and initially standby uses about 25w and then it drops down to 5w but never goes any lower.
My method of measurement was just using a standard electricity consumption meter. I only noticed it was using so much when i unplugged the tv for decorating. I have another older sony 32 inch LCD tv , and when this is in standbythe consumption meter does not register any consumption(it only registers whole watts). I wonder if the new TV has some kind of fault. It would be interesting if somebody else could do a similar measurement on a EX503
cheers
For the original poster. You might find the thread I started interesting. I am having a similar issue to you.
