As title,
My module is KD-55X7000E ( 2017y )
I'm trying to change the authentication to enable and wont to get the PreSharedKey( is that same as WPA key? )
If so thanks in advance.
Hi Luvmex,
We'll check to see what's possible and let you know what we find. Meanwhile, maybe some of our members can offer some advice.
Best wishes,
Ed
Hi luvmex
I'm not sure I completely understand what you're looking for.
If you're trying to connect the TV to your Wi-Fi without having to enter a password then you can either use the WPS button on the router which should temporarily allow you to connect without a password before putting the security back up.
If you decide to use WPS, go to HOME - Network - Wi-Fi - Connect via WPS
Win_88
