I've just purchased the Bravia EX537 and have set up my favourite channels and can see them in the guide. But then, after choosing to watch a channel from the favourites in the guide, when pressing the 'Prog' or Channel up and down buttons on the remote it scrolls through all channels, not just favourites. This is unlike any other TV i've had, usually setting up favourites means these are the only channels you see, which is what you want.
Is there a way to scroll up and down only through favourites?
Thanks!
I just stumbled across a method to see only favourites when the remote doesn’t have a heart or discover button.
Press guide button
press action menu button
choose guide source
choose your favorites list
tada
now if only Sony would’ve told us that!!!!
unfortunately this still didn't work for me. Still Shows all the channels in the guide and when I use the up down channel buttons.
I have a KD-55AF8 from 2020.
I also haven't been able to find anywhere where I can select to use a favorite list. Several places in the menus where I can setup favorites but just no way to actually use them. Really odd.
If I try the above my only options after selecting "choose guide source" is to select digital or analogue.
Instead I have had to delete the channels I don't want.
Just bought a new xh9005. Tuned in both satellite and terrestrial channels. I made a favourites list of a small mix of both, selected fron Digital (terrestrial tuner) and General satellite.
As long as I only use the guide to change channels, it seens to stay on my favourite source, and the ch +/- traverses it no problem, but its all too easy to have the epg revert to just the digital list. My worst problem, when I power off, and later on again, half my terrestrial channels are missing from my favourites list, exactly all those from on of the two terrestrial Mux which covers the full range of channels tuned in. They remain in the Digital list intact, but disappearfrom the Favourite list after each power off. All I was trying to do was create a very short list of the core terrestrial channels plus about 5 satellites, so herself can quickly scroll through the terrestrial and then onto Skynews, withour having to bring up source list bars or hopping between Digital list and massive Satellite list.
Hi Deezell, are you using the Sony channel Editor?
Yes, ive used the editor. It's of limited use tbh.
Sony tvs to get Google Android interface.
https://www.whathifi.com/us/news/old-sony-tvs-are-about-to-get-a-new-android-tv-interface
