- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi , I would really love some help on how to download my now tv app on the my new 32 inch Sony Bravia KDL32WD751. . This is driving me nuts , plz help me
thanx
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
I would recommend getting in touch with NOW TV for further help.
Best wishes,
Sean Mc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Best wishes,
Sean Mc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same model (less than a week old) same issue. Had to replace my 2013 LG telly which had a HUGE choice of apps. I used Now TV often. Bought a 2016 model Sony... no Now TV app!!! One of the most trusted, high profile TV brands and their 'smart' TV isn't as smart as an older model LG. What's going on Sony???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
They are commercial choices (from Sky), Now TV isn't even for Sony's Android TV range.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Surely this can’t be the case - only just bought my Sony Bravia and cant get Now TV? ???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What model of Sony Bravia TV have you bought? Now (as NowTV is now called) is only available on Sony’s Android TVs.
I’m recommending everybody jump onto Amazon today or tomorrow, and uses these Prime days to get a streaming device cheap, to add any missing apps to their Sony TVs.
If you aren’t a Prime member, sign up to a free trial, order the goods with the Prime discount, and then cancel before the free trial is over 😛
Either a Roku Express device, my preference, or an Amazon Fire Stick; 4K if your TV will handle it, otherwise HD in both cases.
https://www.amazon.co.uk/dp/B07XGMNK9G/ref=twister_B095ZKNCTX?_encoding=UTF8&th=1
All have Now, plus quite a lot of other streaming apps your TV App Store may not provide.
