Hi
I have installed Homestream console 2.0 on my Viao and it shows the TV as a n active device. However the TV is not finding the Homestream server. I have done the follwoing to no avail.
Reset the router, BT home hub 3
Factory reset the TV
gone through server diagnostics the results are PS media Server Succeeded
Viao XXXX@XXX.com Failed
Vaio XXX1@XXX.com Failed
but no Homesream.
I am now at a lost as what to do to next?
Hi there
As a suggestion:
If that still fails
Hope that helps.
Hi there
As a suggestion:
If that still fails
Hope that helps.
Thank you.
That did the trick, the 2nd option worked so easily should have tried that first!!
Excellent - Im glad it worked for you. I really should have wrote that second option first, in a Keep It Simple approach
