Weird situation with a Sony TV KDL-37W5500
Anything plugged into TV via HDMI lead...when turned on...then prevents TV Freeview Digital channels from appearing. Message No Signal on the TV. Switch off the devives connected via HDMI and the TV channels reappear.
Any idea what the problem is?
Thanks
pjah
Hi there
That is a weird problem isnt it. My money is on electrical interference in your situation.
A couple of things you can try:
Cheers.
