Need to connect Wii to Sony Bravia KDL-40HX723. Alreday have connectedSony 3D sytem and Sony Home Cinema system, with Sky Box. All plugs seem to be in use.
you have a scart input on the rear of the set so with the Wii lead and scart adaptor that comes with it you can connect the Wii to the tv in this manner.
