Hi there
If it was working until recently, there should be no reason why it should stop, unless you have made some changes?
I guess, lets start with the most simplest solution first, and work upwards. Can you turn OFF all equipment from the powerpoint on the wall, leave for approx 2 mins, and switch it on again.
If that didnt work, ensure that you have Bravia Sync set to ON
If that doesnt work, please reply back with your exact TV Model number
