Hello guys,
I recently bought this KD-65XG8577 Android TV. I was using the live tv HDD Recording function before on a Phillips Android Tv and it was working just fine. After I've got this new Sony one guess what? Live TV recording or pause not working at all.
I get the following message in the error list:
"Programme could not be recorded. An LNB overload was detected. Please check your satellite connection."
Just to be clear, I called a satellite expert, replaced all the switches, f-connectors, checked the signal and everything is just fine.
I restored factory settings, reconfigured everything again and no success.
HDD registered successfully.
If somebody has any tips or ideas please let me know, as I do not have any option left.
Thank you in advance.
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
Hi there,
Yes, latest firmware is installed. Had the same problem also before the update.
best regards
I still don't have a solution so if anybody has any idea, please let me know.
Thanks,
Regards
