Does anybody know whether it is possibile to use a USB pen to record via the HDD Rec function of Bravia HX series? If yes, what are the minimal requirements?
Many thank in advance.
Stefano
Yes you can, as long as the Pen is at least 32GB. You won't be able to transfer recordings to another device though. You will only be able to watch them on the TV that recorded it.
