x
Hard Copy Manual for KDL-32W705B
SOLVED
fossmartin
Explorer
I am trying to obtain a hard copy manual for the SONY KDL-32W705B without any success. SONY UK have not been helpful at all and I was wondering if there were any other sources I should look at. SONY do provide a lengthy reference guide but this is near enough useless.  Any assistance would be apprecicated.
12 REPLIES 12
Anonymous
Not applicable
Hi there
Unfortunately I still cannot upload PDFs here, but I have taken the liberty in converting the iManual to PDF for you.  Please see the link below:
https://www.dropbox.com/s/4kkwcw39byz8vqf/iManual%20-%20%28KDL-32W705B%29.pdf
Hope that helps
fossmartin
Explorer
Very many thanks for your valued assistance. At least I now have a copy of the I-Manual on my PC in PDF format which I can browse or print at my leisure.  I think the PDF file should be made available on the SONY UK support website as it will at least allow other consumers to view/print the I-manual.
Once again very many thanks for your support.
Anonymous
Not applicable
No problems :slight_smile:  Good luck with everything.
I have also passed on your concerns to Sony as well.
