I have a BDP-S390 player. Player connects to the net without problems.
I quickly tried the Internet apps, everything work fine.
Only one problem:
From the Sony Entertainment Network category I wanted to try Forte audio player.
(The app's brief description says: It plays mp3 files on your tv)
The app launches but an http erros screen comes up, telling the http request was sent to a https port.
Q1: What is this app supposed to do?
Q2: Why is the error message?
TIA,
Zoltan
Problem solved itself - the Forte Audio Player is no longer available on SEN (at least not in my territory).
It simply disappeared from the Apps list.
