Just bought an FMP-X5 4k media player to connect up to my KD-65X90005A.
I was so thrilled to finally see some 4k on my TV after nearly a year of owning it. I went straight to Netflix and put House of cards on to see wht the 4k picture was like and it was great but the sound kept cutting out randomly.
i checked all the setting and connections. Still the same. Googled the problem and couldn't find any thing about it. I have every thing set up as it should be. I have a £100 HDMI lead connecting the media player to the £5000 tv, I didn't expect any problems. I have tried changing settings, swapped the HDMI cable, resetting both tv and media player to factory default. Checked the software update and they are on the latest firmware.
i have tried a few 4k samples on USB stick and same problem with the sound, which proves it's not just the Netflix App. But now when I go into Netflix and go to the Ultra HD 4k programmes they now only say HD, no 4k option, just plain old 1080. Utterly disappointed. I tried Sony's CIC and Netflix and still haven't resolved anything.
The Internet connection is hard wired to router. The speed test shows that the broadband is running at 68mbts tonight which is 3-4 times higher than Netflix recommends.
Has anyone had the same problems, or have any ideas. Just feeling so down about all this overpriced Tech and just not getting what I paid for.
Hi there
As you have tried both Sony and Netflix support, theres probably little that this forum can do to help. I have not heard or seen the problem you have described. The only thing I can advise, is also post this same question over at the AV Forums, they have a rather big "owners thread".
https://www.avforums.com/threads/sony-kd-x9005a-4k-owners-thread.1797854/
Hi
When you try to buy the FMP-X5 online from Sony's website, although it names your TV model as supported, it also then takes you to the following page where it asks for your TV serial no. in order to check if a hardware upgrade by a technician may be necessary in order for it to work:
https://www.sony.co.uk/support/en/4k-hardware-upgrade
I wonder if this is the upgrade you need.
Have you got it fixed yet? I am curious because I have the 55" version of your TV but am on the fence about getting the FMP X5. Would be curious to know how you like it and how much content is available, whether you feel it's been worth the money etc., once you've had the upgrade done. For example, are you now able to watch all that extra 4k Netflix content you mentioned on your TV without issue?
Thanks
Jeff
J-Star : This particular post might be of some interest to you :
