My Bravia KDL32 EX 403 has died and the red led flashes 7 times between each 3 sec pause. Anyone know what this means. I have unplugged it and reconnected after a few minutes - result , an initial spark of picture then blank screen and 7 red led flashes again.
you need to contact your local Sony Authorised Repair Centre as there is a fault with your set
