I notice that firmware updates for my TV (KDL-46EX723) appear to have disappeared from the support website.
http://www.sony.co.uk/support/en/product/KDL-46EX723
Any ideas as to why that might be? I know it's a fairly old set, but I'd have thought that they would continue to make the latest version available.
I see that the firmware updates have now reappeared (at least for my model).
Thanks
Hi there
Yes you are correct - It seems that many of the firmware updates for 2011 TV's have disappeared off the new Support website.
I have reported the issue.
Great, thanks.
You are correct - Just tested a couple of other models that also had the same issue, and FW is there as well.
