x
profile.country.RO.title
vldpopi
Explorer
firmware update
hi, i have an kd 43 xe 7005 running the version v8.673 - 1000 - 1.280 - 0000
and i’ve been read on the net that the new 8.674 version is available since 21.11 my bravia doesn’t found when i search for the new vers. i’ve been refreshing the internet content but without luck. why can’t find the newest version if out there’s available for my bravia ? thanks
3 REPLIES 3
profile.country.GB.title
LightFoot
Specialist
Hi @vldpopi. This is available now for USB update. It is not unusual for the internet update to be made available several weeks later than the manual update. If you cannot wait and are confident you know what you are doing then you should perform the USB update.
https://www.sony.co.uk/electronics/support/lcd-tvs-xe70xx_x70xxe_x72xe-series/kd-43xe7005/downloads/...
vldpopi
Explorer
hi, i see... ok, then i’ll must be wait... anyway seems everything works just fine now.  thanks you for the answer.
vldpopi
Explorer
ive been upgraded via internet update. the process in self works fine but, i have an vague feel that the quality of the image drops .. mean the colours, sharpness barely not the same, also at some channels i saw more often now some drops or pixelated transitions... that could be possible with this new v8674 or isn’t any way possible that the image quality to be affected by the update.
