I just tried to watch a program on BBC i Player and keep getting the following message can someone explain what it means.
Internet failed because download content exceeded system memory unit
My tv is a Sony Bravia
Hi @muffin1947
I think something must be broken again their end 😞
Have a look at this thread:
https://community.sony.co.uk/t5/other-tvs/kdl-47w805a-tv-message-of-system-memory-limit/td-p/2263247
cheers
Hi @muffin1947
Do you still have the TV model: KDL-42W653A and is this error is on this particular TV.
If so, this particular error was reported fixed by the BBC in December last year. I have been hearing reports that this might have re-occured, but no one is replying back to confirm their model number of the TV. Without a model number I cannot report this up the chain via Sony to the BBC.
At current it is confirmed as:
Yes I still have the KDL-42W653A and this is where the problem occurs.
internet download failed because content exceeded system memory limit
I have this error on a Sony KDL-32W705C- I also have a problem on the same TV in that I can load Netflix but when I select a program/film to watch it loads very slowly and then drops back to the TV channel
