- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
dvd connection
ive just bought a sony kdl46w905,and no matter how many times ive tried following the guides,when i try connecting my blu ray player,there is no picture at all,its a phillips blu ray player,but that shouldnt make a difference. ive tried everything,checked the leads,made sure its all connected,but still no picture at all,help please!!!!!!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
tried again,blu ray plugged in and playing,screen says hdmi3 player1(philipsbdp)
but just a black screen,no picture.frustrating as hell,wanted to see how good a quality blu ray is
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
What model bluray player?
Edit: Im assuming that the bluray player is switched on, and you have selected HDMI 3 (as the input source) on the TV?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
phillips bdp3100
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ye,blu ray player playing,hdmi3 selected,no picture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try the following (ensure all devices are switched on)
- On the phillips remote, press the HOME button and then the numbers 731
- If that fails, turn all equipment off from the wall
- Unplug the HDMI lead from the TV, and plug it into a different port (ie HDMI 1)
- Turn TV on
- Turn Bluray on
- Ensure TV is on the correct HDMI channel (ie HDMI 1)
- If that fails, do you have another HDMI lead you can test with?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
tried the 731,no joy.ive tried different hdmis and made sure ive chose correct source. surely it cant be a fault on the tv,ive checked the lead,it works fine,and checked the blu ray player with another tv,it works fine,dont tell me ive bought a tv with a fault!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hmmmm.
To rule out a fault (or confirm), I guess you will need to test another device on the HDMI port. But its also worth testing another HDMI cable too, especially if its an older one (or a generic el-cheapo one) - as it could be a HDCP issue.
Other than that, Im unsure if I can assist any further to be honest. Give the above ago, as im sure support will suggest the same thing
Hope you get it resolved anyhow.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks anyway.
