I've just got your reply, sorry about the delay in getting back to you! Now the DVDR - is totally not working! Before we could switch on the recorder and access previously recorded material. But we could not access the program guide to record anything. Now I cannot access anything! It won't update and it won't let us access any of its settings!!
I have spoken to a TV repair Guy, who has stated that by unplugging the recorder and swapping over the TV's the recorder has lost it's software program. He has quoted £75's to reinstall the software and everything should work. Does this sound about right! However I am quite a bit miffed by this! I am going to contact Sony to say that if you can't unplug your DVD Recorder without it costing you £75's each time. Then that isn't good enough!!
Is there any help & advice you can give us that would be greatly appreciated!!
My email address is -
<Email address removed - personal details are not allowed in the forums>
Thanks for your help & time!
Kind Regards.
JAMES SIDNEY!!!!
Hi there, at the moment ITV Player and 4OD is not available on any Sony TV / Device. However I am sure at some point they will become available. But considering the age of the TV, I very much doubt the TV will support it anyhow.
There is a length thread : HERE if you would like some reading
In regards to the RDR problem, I think what the repair guy is referring to is:
But that would only occur in the middle of a firmware update. If you wasnt, it sounds like a slightly different problem to me. Unplugging the power cable in NORMAL use would not "loose" the software. However if the RDR does not even power on, I dont think there is much we can advise, except for a repair.
