I know it sounds like a very, very stupid question, but does it really improve the HD of a TV? I own a 1080p Sony TV and the quality is not that good, so I was wondering if getting an antenna of this sort would massively improve it? If so, does anyone know a good one that's under £30? Thanks
Hi there
With digital tv, you either get a signal or you dont. So, unless you are experiencing a break up of picture or a black screen, a new aerial or an adjustment will not make any difference.
What channels are you experiencing poor quality? Can you describe it a little more?
