TV: KDL-40HX803
Player: BDP-S580
Audio: HT-AS5
Transmitter: TMR-BR100
Glasses: TDG-BR250
All connections via SONY HDMI cables
Upon inserting my first ever 3D disc (Pirates of the Caribbean, On Stranger Tides) I get a popup:
"This disc has recognised that your player and/or display does not support 3D playback"
... So, which part is wrong? Hopefully it's just a configuration setting, but if so, I can't find it.
I've made some progress. The SONY UK website lists the Remote Control for my TV as the RM-ED034 but I have the RM-ED035 - the major difference is that I don't have a "3D" button. This might explain my problems?
I'd make sure you are running the latest firmware on all the devices. You can toggle the 3D manually by pressing 'options' on the remote handset and you should se the 3D menu there.
Hope this helps
Aha! Now we're getting dangerously close. The only 3D source that I had was my "Pirates" BluRay disc, but when that's in the BluRay player, the "Options" on all of my remotes takes me to the BluRay player options, where there is no 3D Menu...
So, to get to the 3D Menu, I had to put the TV back into TV mode. Then, I had the 3D menu. 3D display was off, the other choices were "Simulate 3D from 2D", "Above/Below" and "Left/Right". So I went for "Simulate".
Then, when I went back to the BluRay disc, it all worked.
This leaves me in Simulated 3D when I'm watching ordinary TV programs, so presumably I just turn the 3D off again.
Message was edited by: swiftie
