I set up my HDX853 yesterday and when going to internet settings a code came up which asked me to put in my computer. My brain went blank and couldn't think what this meant and I didn't write it down. I now have a new network listed on my computer called Direct-CM-Bravia and now realise the code was to allow access to it. My problem is I now don't know where to find this code in the TV settings
Hi - What are you trying to do? Could always just go through the network setup process again, or worst case run a factory reset if you want to start from scratch?
