I know that it is possible to display the strength and quality of a digital signal, because I have done it. But I can't remember how. Can anyone help? I have a KDL-32EX603.
manu-settings-system information- and there You can see strength and quality of a digital signal, SW version ect.
Regards
Damac
Many thanks Damac, I knew it was there somewhere. Wouldn't it be nice if we could have a good old fashioned comprehensive user manual?
Hello,
The comprehensive manual can be found on the Sony website if you have a PC.
I had problems with it, until I downloaded and unzipped it to my desktop - see attachment in following thread (I-Manual).
There is a lot of information which is missing from paper manual.
https://www.sony.co.uk/discussions/message/652141#652141
Hope it helps.
