Is there any differece between the FWD and the KDL series? The reason for asking is that I can get a FWD60NX720P cheaper than a KDL60NX720P.
Best regards,
L
Message was edited by: lazerharp
The FWD is a b2b display - so likely doesn't have a Freeview tuner nor some other consumer elements I guess. The KDL prefix is the standard consumer model - although that particular one might I think be an older 2011 model..
Hope this helps
Thats what i thought. It would be great to find out if it's anything else than the tuner as it dosen't matter to me ( using box with IPTV).
Thanks for the answer,
L
Looking at the spec - the only obvious thing is a tuner: it has HDMI inputs so you are all set there.
Warranty might be handled differently as its b2b - not sure they are serviced in the same way, so check with your dealer
Thank you for the help.
Best regards,
L
