Hi there
Try the following
In "Program Sorting" you should be able to rearrange and delete the desired channels.
Hope that helps
Hi Alberto.
Here is the manual of your TV. Just go on page 101
http://pdf.crse.com/manuals/ADJ5100121.pdf
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
I'm sorry Alberto,
it was this manual on page 101:
http://download.sony-europe.com/pub/manuals/consumer/5100111.PDF
(I don't know why there're 4 different manuals!!! See even here: http://www.sony.co.uk/support/en/product/KDL-40W5840/manuals)
Hi Alberto
-OR a “mistake” on manual (on Italian manual for example (page 111), there isn’t a “deleting” option)
-OR other model (manual is for more models KDL-xxV58xx and KDL-xxW58xx),
-OR other firmware version.
As you can see on Sony’s Support site, there’s also a firmware update: http://www.sony.co.uk/support/en/product/KDL-40W5840/downloads/FW_Bravia1740SA
Last firmware version is: PKG 1.740SA
The only way that remains (but it’s too hard and not so quick way!!!) is the Digital Manual Tuning, in order to select which channels to store. In that case it must be also disabled, in Technical Set-up, the “Auto Service Update”.
PS
Be careful!!!
Once updated:
“...Can I install an older version of Firmware?
Installation of older firmware is not supported...”
