I have a sony bravia KDL-46NX703 and I find it difficult to type the text through the remote. Can anyone please suggest what alternatives do I have to connect a remote/wireless keyboard to the tele so that I can enter the text using the keyboard.
Thanks
Vivek
Hi there
Unfortunately you do not have mnay options. If you have a Smart Phone, you can download a program called Media Remote.
https://play.google.com/store/apps/details?id=com.sony.seconddisplay.view&hl=en
Thanks for the reply, I had already tried installing the app on my Android device but the app fails to detect the TV 😞 and therefore does not works. Any other suggestions ???
Regards
Vivek
