I have tried, I think, every permutation but without luck - there may be a fault but I wouldn't know where.
I have : KDL 32EX600 plus an HD Freesat box with 1 x HDMI slot, 1 x SCART + RF co-ax's plus an LG HD DVR with 1 x HDMI and 2 x SCARTs and RF co-ax's.
I do not use a co-ax aerial.
HDMI #1 port on Bravia appears to be u/s. I'd be grateful for a cable by cable guidance so I may deduce if there is in fact a fault somewhere.
Hi there
I do not know what "u/s" means when you mention it with HDMI 1
To switch between the devices, press the input source button on the remote control.
If this doesnt work, can you describe what has changed? Has this setup worked before? Describe what is not working? And any other details that may assist?
u/s normally means unserviceable or faulty.
LOL - easy when you know the meaning
I like the : FUCT (Failed Under Continuous Testing)
