Hello, is it possible to connect a keyboard to a Sony Bravia KLD-46EX655? Having to use the remote control to enter text when using the internet is rather time consuming. Would it also be possible to connect a mouse? Thanks for your help.
you cant physically connect a keyboard to a television but the link below will give you what you need.
http://www.sony-europe.com/support/en/product/KDL-32EX723/downloads/Remote_Keyboard_Lite
Hi there,
I have two Sony TVs can you confirm whether the Remote Keyboard Lite software will work on both of the following Sony Smart TVs
KDL-22EX553 and KDL32W653A
Thanks in advance
