I have a Bravia KDL-42W706B. I have a USB with some media on it attached to my BT Home Hub. My Mac identifies this USB device under 'Shared Networks' and lets me view the content.
Please can someone advise how I can view this directly from my tv also?
Thanks!
Hi Benlevy,
Welcome to the community.
The file you want to view will have to be supported. You can find out more about this here.
Best wishes,
Ed
Hi benlevy,
I've found the available Home network functions that your TV supports in this Guide: https://bit.ly/2UVirYy. However, since what you're looking to achieve is not the usual setup for the DLNA network, I would suggest that you contact the router manufacturer to get more information on displaying this content on your TV.
Thanks,
Vanilla_
