Hi recently the colours on my 37"Bravia have been off, skin colour has gray -green patches on it and a silver edge like a film negative and all other colours are affected white is sometimes silver, this only happens in some programs and is not the sky unit or the bluray as it happens in both of these, it is hard to explain red has brown patches it is as if the pixalisation is faulty.
Chack Your connection-antena or cable. Make reset and auto start up. See do You have latest update from support page. If You writte again, tell as Your model. It is about tuned chanals.
http://support.sony-europe.com/main/index.aspx?site=odw_en_GB
Regards
Damac
