Clock is shown in the first line of the info banner for Digital channel between channel name and channel number, on the second line on the rigth on HDMI input. At least on 2013 tv, but 2014 should be the same...
Thanks for the reply - I was aware of the info that you have mentioned, it's just that the old TV had a small clock permanently in the bottom right corner of the screen. This is what I want !
Other buyers of the newer models seem to have the same issue if you look around the forums .
Best regards,
Mick
That's the way it is, it doesn't seem a big problem to me...
