seen on ebay for forty pound from china , are theses the real thing ??? prices vary so much most expensive pair 125.00 pounds , please help
Hi dean1972,
i can understand your dilemma, however you will never know what you are getting for sure, naturally if you pay using paypal your protected but here's the thing yes they are cheap but did you consider you may have to pay import duty?, plus the added worry of them being in the postal system for up to 21 days!, they could be wrecked by the time you get them, the other end of the scale, Littlewoods sell them for £129 from only £1.61 per week, Richer sounds do them for £79.95 and here on the Sony site £80.99 the added bonus is if they are faulty at least you wont have to go half way round the world to change them!.
Hi dean1972,
thankyou very much , have been looking on amazon and found them for 59.00 inc delivery which is the best price around the prices are comming down which is good think i will hold on for a few weeks to see iff price drops further thanks once again ,dean.
dean1972,
these are the ones and cheaper still mate!
http://https://www.amazon.co.uk/Sony-TDG-BR250-glasses-active-shutter/dp/B004UAU7CC/ref=sr_1_18?ie=U...
sorry, take the bit of the beginning of the link (forgot)
Message was edited by: Bravia55HX923
Try looking on amazon. Also, don't just look at the price, look at the price-quality ratio.
