This question no doubt shows up my lack of technical knowledge. Although the instructions tell me to use the USB port on my TV can I charge my BR250 3D glasses using the USB port on my PC.?
yes you can indeed!, if your blu ray player has a usb port you can use that as well including most modern mobile phone chargers.
Yes. Shame these glasses are tight and uncomfortable.
As you may know if you've ever visited an optition the problem with most 'standard' of the shelf glassess is the the frames of glasses generally don’t tend to automatically fit everyone, unless they’ve got a standard sized face..
Awful things. Just read the online reviews.
