I have tried this, but I cannot get it to work, I have bought a digital audio cable, but nothing happens, maybe I need to connect something else, I also have a cable black pin on one end and red/white on the other, but the TV has no red/white but all sorts of other L/R inputs (black and red).... any help would be greatly appreciated...
Hi there
I am assuming that you are referring to a Digital Optical cable (such as THIS) - If so, this will work when connecting it to the TV.
This should then work.
Ah, I have done all of this apart from repeatedly pressing the audio in button... I will try this now!
well I've tried that now, and still no joy...
Sorry, got it working after all, the connection came lose after hanging the TV back on the wall.... I also still had some other ones plugged in, so removing them and fixing the optical cable did the trick! Many thanks for the help!!
Not a problem, glad its now working
Have Fun !
