- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Bravia XRr48 A90 Freesat
Although the Freesat programe guide lists all the available stations, none of them show the actual programes, although they are all watchable.. Is this normal or is there a way of correcting this.
Secondly I can't seem get my local channel (HTV) only London. Is it possible to correct this also.
I've had this TV only a month so still trying to find my way around so any help would be greatfully received
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I think this might require a retuning for the satellite cable.
However, if it's feeding multiple TVs, make sure that the main one is plugged in, no converts, or splitters or anything, that might help.
And if you're still missing a specific channel, try to manually search for it, cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks for info, but as previous TV picked up HTV, current is picking up London, shouldn't the replacement pick it up also? If not, as the ariel is only servicing the one unit, I will take your advice and call in the ariel guy.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No the replacement doesn't have to follow the same specs. Ideally you want it to be a simple swap, but it's not unfortunately, so if that didn't help then yea it's better to contact an aerial guy.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks for info, looks like that's the way to go.
