Hi, I recently purchased the Bravia KDLEX653 40" and require a replacement TV table top stand.
Can someone advise where this can be bought? I live in Ireland.
Thanks,
Cathal
Hi there
A couple of places that should deliver to Ireland:
Just type in your model number (KDL-40EX653) into the search and should come up with some parts.
Thanks very much
