Hi guys
Recently bought the Bravia KDL50W829 & have it connected to a satelite box via HMDI.
I have it connected it to HDMI 2 but every so often the TV will turn itself into stand by for a few seconds then turn itself back on??
Any ideas?
Hi there
First couple of things to try:
If that fails, you will need to figure out if its the TV itself or any device connecting to it that is causing the problem. Therefore:
If it is the TV, you will need to report this to Sony to get this resolved. See HERE for contact details. If it is a device connecting to the TV, try replacing the HDMI cable as a first step.
Hope this helps.
