I bought KDL 32V5810 anticipating to receive HD channels freesat. The one I have is DVB-S and the Disecq is 1.0. Has anyone tried to use motorised system, does it work with this receiver? are the HD channels on free sat from DVB-S2. I dont have DVB-S2 on my TV, DO THEY COME WITH THIS MODEL? THANKS.
Hi elfieN and welcome.
The specifications say DVB-S2 here: -
http://www.sony.co.uk/support/en/product/KDL-32V5810/specifications
What firmware version do you have installed?
http://www.sony.co.uk/support/en/product/KDL-32V5810/downloads/FW_Bravia1740SA
Thanks Blencogo for the reply. I have the recent update firmware 1740SA but this didnt change the specification. From the specification its being indicated that its DVB-S2 but it is not. Is it that there are 2 models: either DVB-S or DVB-S2?. Rgarding using motorized satellite, will this receiver be able to rotate a 90 cm dish?
