I can’t sync my new Bravia TV with my LG Soundbar. If I have the Soundbar on, I get audio from that and the tv speakers, giving an awful echo effect. Where is the setting to disable the tv speakers so I can use the Soundbar? In the Sync Menu, the ‘Speaker’ option is greyed out. I am using the optical cable to connect as there are only 2 HDMI ports on the Bravia and I am using these. Anyone else had this problem?
Sorry, found it now from the Options button on the TV remote. Just being a bit thick, sorry.
