BRAVIA-KDL-42W655A slows down or restarts after it connects via mesh or mesh is in the same network
I have a TV in a different room. I have extended my internet connection in that room via cable and used a router as mesh. All devices work great, but the Sony Bravia KDL-42W655A. The TV gets very slow when I start the mesh. It does not matter if I connect via WiFi or via cable.
The main router and the mash are AVM FritzBox 7520.
If I connect the TV with cable directly to the main router and take out the mash, the TV works fine. The problems are when I introduce a mesh.
How can we fix this?
Have you set the internet-facing Fritz!box as a Mesh Master?
