Can anyone help, please,
I recently bought the above tv and no matter waht I try I can not get this TV to comnnect to my LAN.
The lan is a wired system with direct connection (via Cat 7 cable) to a BT router which is also linked to a NETGEAR READYNAS 6 PRO, where I store my movies, music etc, hence, the purchase of this TV, also there appears to be a firmware update for this model, but im unsure as to the method to use to carry out the firmware upgrade.
If the considered opinion is that I have wasted a not inconsiderable ammount of moneythen I can still send the thing back and buy a SAMSUNG
Hi there
Im not too sure on why you cannot connect your TV to your home network. In the case of a wired connection, it should be the case of connecting the ethernet cable to the TV and router and choosing Network Setup in the TVs settings and running the Automatic setup from there. Baring a hardware fault on the TV, I think its prudent to try the first few steps in the troubleshooting process:
