Hi, I have a bravia kdl-4052530 and the standby light is flashing 3 times. I believe this is a fault associated with the lamp? If I disconnect the TV from the mains for a whiIe I get picture and sound for a few seconds before it switches itself off. Can anyone advise me further?
Hi stumap,
welcome to Questions & Answers..
If the stanby light is flashing red then this indicates that the TV's self diagnosis mode has been activated, I suggest you contact your local authorised Sony service centre and inform the them of the sequence that the Standby light flashes. Use the following link to find your nearest: Authorised Sony service centre - http://support.sony-europe.com/repair/asc/asc.aspx?site=odw_en_GB
Hi stumap,
i need this panel for the TV the modern No is KDL 4052530 And the part No is LCD PANEL 1-802-267-11 This is for Sony TV.
