I'm connecting a laptop (new Compaq) with my Bravia via HDMI. The picture is perfect, but no sound. I have tried both HDMI connection sockets, with the same result. Solution please?
Hi there
You will need to go to the sound settings on your laptop, and enable audio over HDMI (uncheck "disable"). See screenshot below (Windows 7)
Many thanks - now works perfectly. What an idiot not to have thought of that....
