Network icon top LH corner of Home screen is greyed out with exclamation mark. What does this imply?
Since my network connection is OK. I have access to all apps and screen mirroring with no problems.
Hello Peter,
Though this first occurred a couple of days ago, just today when I turned it on my TV was good enough to tell me an update was available.
Promptly installed it and everything now OK.
Presumably that's what the icon was trying to tell me, only the message was a little tardy getting through!
Better late than never, but anyway thank you for the advice.
Barry
Is your TV software up-to-date? (check sony.co.uk/support for the latest software).
In addition please check the clock setting of your TV. If it's not correct this issue might occur.
Hello Peter,
Barry
