Recently bought a Bravia 32WD756BU TV, but when trying to use Sideview, add device, it can't find it even by typing in the correct IP address.
Any thoughts?
Thankd
Hi there
I was just about to reply to you about checking network settings etc etc, but thought it was worth a look at the Sideview compatibility list.
http://info.tvsideview.sony.net/en_ww/home_device.html#bravia
What is interesting is 2016 Non-Android based models are not supported. Your TV model is under "KDL-W75xD" I am struggling to find a plausible reason on why Sony would do this? At the moment you're out of luck on this, but 'hopefully' they will enable compatibility in the future.
