I'm able to connect my laptop (full hd) with HDMI cable successfully, but after a while (randomly) the tv screen just turns in pink/blue colors, and I need to refresh the input channel (hdml1 to hdmi2).
I have updated the firmware to the newest version (verified in tv settings) following the instruction of the support site, but it still turns the colors.
Do I have to update other driver/firmware? or maybe a Patch?
My laptop graphic card is: "Ati mobility radeon 5830", but I don't mind it's the problem.
Thank you very much.
Hello,
I had a similar problem, and after playing around with the settings managed to solve
Firstly I updated the driver (ATI Cataluyst Drivers 10.10 was released on October 22nd).
Go into the Ati Catalyst Control Center.
Choose Desktop&Displays.
Rightclick in screen nr.2 (Sony TV) and choose configure.
Enter Pixel format and choose RGB (FULL PC).
Upto now no problem with pink picture, although I don't understand why -but at leastit works:smileyhappy:.
Hope it helps.
Hi
I'm having the same problem. It doesn't seem to matter what hdmi source i plug into the tv after a while it goes pink/blue. so I was just wondering if you had any luck with the issue.
Thanks alot
Jon
Hello,
Hope it helps.
I have the same problem witha BRAVIA 40BX400
Experienced the same problem when connecting with two seperate laptops. 1st laptop has an ATI3*** graphics card. Fixed the problem simply by setting the resolution on to full through windows.
2nd laptop has a higher spec graphics card ATI5***.Tried ATI control centre procedure as above but no good.
Sony need to fix this soon or I'll be taking it back.
Message was edited by: leelouise
did you find any bugfix? did sony solve this issue?
Same problem.please any help?
