Hi does anyone know where or if I can get the wall brackets that came with the TV kdl-50w829b as I have had the TV for a while and cannot find them anywhere so was wondering if I can order them anywhere
Hi @midavis8032
You can buy VESA adapter kits so you can use any VESA wall mounts. Just one example:
https://www.amazon.co.uk/Sony-Fixing-Kits-Adapter-Bracket/dp/B082V1MZF7/ref=sr_1_1_sspa
