I have a Bravia KDL-46V 2000 (46' LCD TV) and in moving house have lost the bolts/screws witch hold the wall bracket to the rear of the TV . Can anyone help please,a few bolts are cheaper than a whole new bracket,thanks
I think the bolts are stock M6 size - this thread might help?
http://www.avforums.com/forums/tv-projector-brackets-mounts/768871-sony-wall-mount-screw-size.html
Thanks
Thanks
Thank you very much looks very good thanks again for your time and help
